" /> Stats question - Genesys CTI User Forum
Author Topic: Stats question  (Read 4123 times)
Offline yahoo
  • yahoo
Stats question
« on: August 12, 2009, 08:47:39 PM »
Hi All,
I am trying to capture stats for CCPulse. In the genesys statserver doc it was given
Calls_Entered = Calls_Distributed + Calls_Abandoned + Calls_Cleared, where
Calls_Distributed = Calls_Answered + Calls_AbandonedFromRinging + Calls_Forwarded + DistributedToAnotherQueue (*)
In the above equations could any one explain me what is the difference between  Calls_Cleared and Calls_Answered?
Thanks in advance
Offline Fra
Re: Stats question
« Reply #1 on: August 13, 2009, 09:07:22 AM »
a call is cleared when was sat in a Virtual Queue and, according to the strategy you were running, it stopped waiting for a target (therefore was neither distributed, nor answered, nor abandoned) and jumped onto another Virtual Queue.
Fra
tony
Re: Stats question
« Reply #2 on: August 13, 2009, 10:30:51 AM »
IMO, Calls_Cleared should also include any default routed (i.e. "failed") interactions...
Offline Fra
Re: Stats question
« Reply #3 on: August 13, 2009, 12:04:55 PM »
Mh, I am not sure about "any" default routed interactions, but for sure when they leave the target block from the red port, the Calls_Cleared stat is incremented.
Fra
Offline yahoo
  • yahoo
Re: Stats question
« Reply #4 on: August 13, 2009, 08:34:13 PM »
So calls routed to ACD  or time out in VQ are calls cleared. Thanks!
Offline Fra
Re: Stats question
« Reply #5 on: August 14, 2009, 12:00:48 AM »
[quote author=yahoo link=topic=4565.msg20316#msg20316 date=1250195653]
I'd say yes in the second case, depends what you mean for the first one instead.
Fra
