" /> CCPulse on Vista 64 bit - Genesys CTI User Forum
Author Topic: CCPulse on Vista 64 bit  (Read 5756 times)
Offline sriley
« on: August 28, 2009, 05:32:58 PM »
Has anyone been able to get CCPulse to work on Vista 64 bit?  If you have been able to get it to work can you explain how you did it?
Offline Koldun
    • Genesys Support
Re: CCPulse on Vista 64 bit
« Reply #1 on: August 30, 2009, 04:13:46 PM »
Try this:
In the properties of the CCPulse installation file (setup.exe), in the tab "Compatibility" you should configure compatibility with Windows XP SP2;
In file "ip_description.xml" (from installation folder) you should add the strings as follows:
[i]--------------
<Platforms OSGroupName="windows">
    <Computer Type="Intel 64 bit">
      <OS Name="Windows Vista" />
------------[/i]
Then install CCPulse application as usually.
skriley
« Reply #2 on: September 17, 2009, 02:45:30 PM »
Thank you.  I will try this.
