" /> Agent Ready but not answer the Call - Genesys CTI User Forum
Author Topic: Agent Ready but not answer the Call  (Read 12426 times)
Offline Xavier
« on: November 24, 2009, 04:16:13 PM »
If a call is Routed to an agent's DN that shows as Logged in and Ready, but the agent does not RequestAnswerCall, is there a way to have the call properly handled or sent to another DN?
I work with Genesys 7.0 solution and switch Avaya
Offline Fra
Re: Agent Ready but not answer the Call
« Reply #1 on: November 24, 2009, 04:37:21 PM »
The Avaya RONA functionality is going to be your friend.
F
Offline Xavier
« Reply #2 on: November 25, 2009, 10:54:04 AM »
Thanks for your reply Fra.
Now, I have another problem, the Avaya RONA functionality is OK with a default call, but not with a direct agent call.
If a call is routed with direct agent mode without answer from the agent, the Avaya RONA functionality change the agent state to After Call Work, but the call is always connected to the agent and not sent to another DN.
Do you have a solution about this problem?
Offline Fra
« Reply #3 on: November 25, 2009, 01:14:46 PM »
So, I guess that the Tserver option 'route-thru-queue' option has been set to 'true', otherwise RONA wouldn't work at all. What you need to check is whether the direct agent calling has been set in the COR of both the agent extension and the VDN where the call comes from. Also, don't forget to create - and verify that they can be monitored - all the ACD Queues (the Avaya hunt groups) the agent logs into.
Offline Xavier
« Reply #4 on: November 30, 2009, 10:34:48 AM »
Thank you again Fra.
The problem is resolved.
To resume, I had not noticed that the configuration of Avaya RONA functionality for default calls and direct calls is not the same. I correct the configuration of RONA for direct calls and it works.
Offline GenesysNewbie
« Reply #5 on: December 05, 2009, 04:13:48 PM »
Hi guyz so sorry ....
Can u explain what is RONA?
Javed
« Reply #6 on: December 08, 2009, 07:43:54 AM »
RING ON NO ANSWER
Offline Fra
« Reply #7 on: December 08, 2009, 09:08:15 AM »
Redirect On No Answer. It's an Avaya switch feature that enables call transfer when an agent extension rings out with no answer.
F
Offline yolyoly
« Reply #8 on: November 03, 2014, 12:44:31 PM »
What if the switch is Alcatel? Is there RONA? No meeting information.
« Reply #9 on: November 03, 2014, 01:39:20 PM »
As told you on the ALU forum, check TServer guide for Agent no Answer options.
Offline blakshmikanth
« Reply #10 on: November 03, 2014, 04:06:39 PM »
In Genesys, you can achieve this functionality by using URS.
* Configure agent extension 'event_arrive' option to 'ringing' so that it can be monitored by URS
* In strategy, use function 'SuspendForEvent' and select TEvent 'EventEstablished' with your timeout value
* If the call is not answered, then you can set agent into 'NotReady' by using 'SendRequest' function
Refer URS deployment guide -Chapter 3 - Miscellaneous functions - SendRequest for more information.
Regards,
Lucky
www.lakshmikanth.com
« Reply #11 on: November 03, 2014, 04:20:21 PM »
Alcatel doesn't support that blakshmikanth
« Reply #12 on: November 03, 2014, 04:54:05 PM »
Thanks for correcting me.
Regards,
Lucky
« Reply #13 on: November 03, 2014, 05:46:03 PM »
Meee thanks for giving ideas :D
I wish ALU supported that, would be much more flexible  ;D
