" /> GVP ports off-hook in CCPulse - Genesys CTI User Forum
Author Topic: GVP ports off-hook in CCPulse  (Read 2499 times)
Offline Lily
« on: December 14, 2009, 12:45:27 PM »
Hi all!
I have a behind environment, Sip Server > IPCSs.
I still don't know the reason but I've got about 6 ports in the off-hook state. They've been in that state quite a long time, the only thing I can do for it to work is to delete and recreate the port.
Has anyone seen anything like this before?
Is there an option in Sip Server I can set for it to reset the port if it is in the off-hook state for some time?
Thanks in advance!
Offline Avi Jai
Re: GVP ports off-hook in CCPulse
« Reply #1 on: February 10, 2010, 03:21:45 PM »
You can use the Genesys TestPhone to make the port on-hook. Connect the TestPhone with SIP Server go to Event tab and select EventOnHook put ThisDN as the port number and then click Event button.
Thanks!
