" /> EventEstablished is not being issued? - Genesys CTI User Forum
Author Topic: EventEstablished is not being issued?  (Read 3628 times)
C.J.
Hi, folks,
there is a little problem I wanted to check with you all. It has to do with TServer (5.1.070) not issuing EventEstablished after a call was answered with TAnswerCall.
This problem started to appear only few days ago; however, no matter how many times we reboot it, the problem persists. What is causing this problem and how can this problem be fixed?
Thank you,
C.J.
Marked as best answer by on Today at 11:37:19 AM
Iwamura, Ken
  • Undo Best Answer
  • We have the same problem. We fix it by TServer upgrade. You have old server. You must get newer one.
      Šâ‘ºŒ›ŽŸ
      “ú–{‚t‚m‚h‚r‚x‚r
