" /> Filter on statistics - Genesys CTI User Forum
Author Topic: Filter on statistics  (Read 3448 times)
Offline dmicu
« on: March 11, 2010, 10:40:42 AM »
Do you have any idea why on a template with Email Java statistics on which I applied a filter, this filter is not taken into consideration?
In the log of Stat Server, the filter is identified:
2010-03-11 10:17:32> Client: Message 'NewAPIOpenStat'
'OBJECT' 'StagingArea' (14)
'OBJECT_ID' 'AUSTRIA'
'STAT_TYPE' 'IxnQueue_Email_Entered'
'VOID_VALUE' TKVList Length 62
'Filter' 'CG_Bronze'
'Insens' '1'
'TimeProfile' 'Default'
'TENANT_ID' 'Resources'
'NOTIFICATION_MODE' 'TimeBasedNotification' (1)
'INSENS_PERCENTAGE' 10
'REQ_ID' 77
'USER_REQ_ID' 1
2010-03-11 10:17:32> Client: Message 'OpenStat'
'CREATE_SUSPENDED' 'no'
'FILTER' 'CG_Bronze'
'DistByConnID' 0
'TM_NOTIFICATION_FREQ' 10
'INTERVAL' 'Growing' (0)
'TIME_PROFILE' 'Default'
'JAVA_SUBCATEGORY' 'EQR Total Entered'
'JAVA_EXTENSION' 'eserviceinteractionstat.jar'
'USER_REQ_ID' 1
'REQ_ID' 77
'CATEGORY' 'JavaCategory' (42)
'Insens' '1'
2010-03-11 10:17:32> Client: Sending message to CCPulse(1716)
Diana
Re: Filter on statistics
« Reply #1 on: March 11, 2010, 10:53:09 AM »
Unfortunately, StatServer doesn't support filters on Java statistics.
Offline dmicu
« Reply #2 on: March 11, 2010, 12:13:31 PM »
Thanks very much Rene.
Do you know in which Genesys document we find this information?
[if it is not documented, I could go to Genesys with a ticket or something]
« Reply #3 on: March 11, 2010, 07:54:12 PM »
You can find that information in "Reporting Technical Reference Guide for the Genesys 7.2 Release" - search for the text "filters to Java-category statistical types". You can find that information in Genesys Knowledge base as well
PS. Don't be surprised by my reference to the document related to Genesys 7.2 release. This is the last version of the document available.
