" /> Multimedia Samples - Genesys CTI User Forum
Author Topic: Multimedia Samples  (Read 5248 times)
Multimedia Samples
« on: April 28, 2010, 05:01:26 PM »
Hi guys,
I'm implementing a chat server on my lab to test before deploying on customer. I have everything ok (I think), chat server is up, webapi is up, webapi samples load, gdesktop is up. My problem is on chat server samples, I always get "timeout occurred" message when hitting the start chat link. The email samples do work fine...I'm lost here...what can be missing? How can I get a log of what may be happening?
PS:can anybody solve the upload issue???? "The attachments upload directory is not writable. Your attachment or avatar cannot be saved."
« Last Edit: April 28, 2010, 05:05:45 PM by cavagnaro »
Re: Multimedia Samples
« Reply #1 on: April 28, 2010, 08:50:37 PM »
Hi Cav,
Check log of WebAPI Server.
« Reply #2 on: April 28, 2010, 10:35:13 PM »
Hi rené,
That is what I'm trying to do but can't find its head...
[quote]
4ea5e2f7|LMS|1.0|webapimsg.lms|7.6.100.01|webapimsg
; Copyright (c) 2000-2009 Genesys Telecommunications Laboratories, Inc.
; All Rights Reserved
; Genesys Web API Server (load balancing) log messages
20000|STANDARD|LB_INFO_COPYRIGHT|LB: Copyright 2001-2009 Genesys Telecommunications Laboratories, Inc. All Rights Reserved.
20001|STANDARD|LB_INFO_VERSIONS|LB: SvcDispatcher servlet - %s, (%s, %s, %s)
20002|STANDARD|LB_INFO_VERSIOND|LB: SvcDispatcher - %s, (%s, %s, %s)
20100|STANDARD|LB_ERR_S|LB: %s
20102|STANDARD|LB_ERR_REFRESH|LB: exception during refresh services table: %s
20103|STANDARD|LB_ERR_RSPSRV|LB: exception during inguiry %s in thread %s
20104|STANDARD|LB_ERR_COLLTAPPL|LB: exception during collecting services: %s
20105|STANDARD|LB_ERR_CHNGAPPL|LB: exception during changing service description: %s
20106|STANDARD|LB_ERR_SCSLISTNR|LB: exception in Solution Control Server listener: %s
20107|STANDARD|LB_ERR_ROOTDELETED|LB: Warning: root application has been deleted in Configuration Server
20200|TRACE|LB_TRACE_S|LB: %s
20230|TRACE|LB_TRACE_ADDSRVC|LB: %s service description has been added.
20231|TRACE|LB_TRACE_DUPSRVC|LB: service description %s has been ignored as duplicated.
20232|TRACE|LB_TRACE_APPCHNGD|LB: service description %s has been changed.
20233|TRACE|LB_TRACE_APPSTATUS|LB: status of service %s is %s (%s)
20234|TRACE|LB_TRACE_BADSRVC|LB: Functionality wasn't implemented ('Mark service %s as bad')
20235|TRACE|LB_TRACE_COLLTAPPL|LB: Collect service %s data.
20240|TRACE|LB_TRACE_COLLTIGNR|LB: service %s has been ignored because its type isn't processed by load balancing.
20241|TRACE|LB_TRACE_COLLTBCON|LB: start process connections of service %s
20242|TRACE|LB_TRACE_COLLTECON|LB: finish process connections of service %s
20243|TRACE|LB_TRACE_REFRESHB|LB: start refreshing services table
20244|TRACE|LB_TRACE_REFRESHD|LB: finish refreshing services table
20245|TRACE|LB_TRACE_APPSTATE|LB: service %s state is (%s : %d) %s
20300|TRACE|LB_TRACE_INITDONES|LB: load balancing servlet initialization done
20301|TRACE|LB_TRACE_INITDONED|LB: Load balancer instance (SvcDispatcher) initialization done
20302|TRACE|LB_TRACE_SERVLETDESTR|LB: Load balancer servlet destroyed
20501|TRACE|LB_TRACE_INQSRVT|LB: received service inquiry by type '%s', tenant='%s' in thread %s
20502|TRACE|LB_TRACE_INQSRVA|LB: received service inquiry by alias %s in thread %s
20503|TRACE|LB_TRACE_RSPSRV|LB: dispatched service is %s:%d in thread %s
« Reply #3 on: April 29, 2010, 02:53:39 PM »
Hum...what initializes this log? I renamed it to see a new set of it but it doesn't appear anymore...
« Reply #4 on: April 29, 2010, 07:31:39 PM »
Hi Cav,
Your posted here content of webapimsg.lms file. It is not a log file.
Please check configuration of Web API Server application in CME (section log) to find out where the log file is placed and post it here.
« Reply #5 on: April 29, 2010, 08:33:10 PM »
That is how I found that file...
« Reply #6 on: April 29, 2010, 09:09:08 PM »
Hi René,
This is the log:
[quote]
Application name: WebAPIServer
Application type: CFGWebAPIServer(80)
Host name:        EBDGENESYS
Time zone:        GMT-05:00
Local time:      2010-04-29T16:15:35.731
UTC time:        2010-04-29T21:15:35.731
Start time (UTC): 2010-04-29T21:15:35.716
Running time:    0:00:00:00.015
Memory usage:    117.309.440
Host info:        Windows 2003, 5.2, x86, 1.5.0_09-b03, Java HotSpot(TM) Server VM, mixed mode
File:            (1) WebAPIServer.20100429_161535_732.log
16:15:35.731 Trc 04112 The Log Output of type 'WebAPIServer' has been created and opened
16:15:35.731 Trc 04110 Option 'verbose' has been set to the value 'all'
16:15:35.731 Trc 04110 Option 'buffering' has been set to the value 'no'
16:15:35.731 Trc 04110 Option 'expire' has been set to the value '20'
16:15:35.731 Trc 04110 Option 'segment' has been set to the value '10000'
16:15:35.731 Trc 04110 Option 'spool' has been set to the value ''
16:15:35.731 Trc 04110 Option 'message-file' has been set to the value 'C:\Tomcat\bin\webapimsg.lms'
16:15:35.731 Trc 04110 Option 'time-format' has been set to the value 'time'
16:15:35.731 Trc 04110 Option 'time-convert' has been set to the value 'local'
16:15:35.731 Trc 04110 Option 'message-format' has been set to the value 'short'
16:15:35.731 Trc 04110 Option 'memory-storage-size' has been set to the value '512 Kb'
16:15:35.731 Trc 04110 Option 'check-point' has been set to the value '1'
16:15:35.716 Trc 04110 Option 'verbose' has been set to the value 'all'
16:15:35.716 Trc 04110 Option 'buffering' has been set to the value 'no'
16:15:35.716 Trc 04110 Option 'expire' has been set to the value '20'
16:15:35.716 Trc 04110 Option 'segment' has been set to the value '10000'
16:15:35.716 Trc 04110 Option 'spool' has been set to the value ''
16:15:35.716 Trc 04110 Option 'message-file' has been set to the value 'C:\Tomcat\bin\webapimsg.lms'
16:15:35.731 Trc 04106 Log Messages file 'C:\Tomcat\bin\webapimsg.lms' successfully loaded
16:15:35.731 Trc 04113 The Log Output of type 'stderr' has been closed and deleted
16:15:35.731 Trc 20200 LB: log library initialized
16:15:35.731 Trc 20200 LB: fetch primary/backup SCS...
16:15:38.569 Trc 20200 LB: Detected Solution Control Server [1]: 'SolutionControlServer' (ebdgenesys:4046)
16:15:38.569 Trc 20200 LB: fetch primary/backup SCS done
16:15:38.569 Std 20100 LB: creating SCS client...
16:15:38.569 Std 20100 LB: connecting to the first SCS (ebdgenesys:4046)
16:15:40.565 Std 20100 LB: connected to the SCS (ebdgenesys:4046)
16:15:40.565 Trc 20200 LB: SCS client created
16:15:40.565 Trc 20200 LB: collecting appications from the root ...
16:15:40.970 Trc 20200 LB: -----------------------------
16:15:40.970 Trc 20200 LB: Loaded tenants descriptions...
16:15:40.970 Trc 20200 LB:    name='RESOURCES'  dbid=101  state=CFGEnabled
16:15:40.970 Trc 20200 LB: <end of list>
16:15:40.970 Trc 20235 LB: Collect service WebAPIServer data.
16:15:40.970 Trc 20230 LB: WebAPIServer,CFGWebAPIServer,ebdgenesys,80,enabled service description has been added.
16:15:40.970 Trc 20241 LB: start process connections of service WebAPIServer
16:15:40.970 Trc 20233 LB: status of service WebAPIServer is 0 (Not active. runMode = Unknown(-1))
16:15:40.970 Trc 20233 LB: status of service WebAPIServer is 1 (Not active. runMode = Unknown(2))
16:15:43.808 Trc 20235 LB: Collect service StatServer data.
16:15:43.808 Trc 20230 LB: StatServer,CFGStatServer,ebdgenesys,3030,enabled service description has been added.
16:15:43.808 Trc 20235 LB: Collect service ChatServer data.
16:15:43.808 Trc 20230 LB: ChatServer,CFGChatServer,ebdgenesys,7007,enabled service description has been added.
16:15:43.808 Trc 20233 LB: status of service StatServer is 0 (Not active. runMode = Unknown(-1))
16:15:43.808 Trc 20235 LB: Collect service MCR_EMailServerJava data.
16:15:43.808 Trc 20230 LB: MCR_EMailServerJava,CFGEmailServer,ebdgenesys,5180,enabled service description has been added.
16:15:43.808 Trc 20233 LB: status of service StatServer is 6 (Active. runMode = Primary(0))
16:15:43.808 Trc 20235 LB: Collect service MCR_InteractionServer data.
16:15:43.808 Trc 20240 LB: service MCR_InteractionServer has been ignored because its type isn't processed by load balancing.
16:15:43.808 Trc 20235 LB: Collect service MCR_UniversalContactServer data.
16:15:43.808 Trc 20230 LB: MCR_UniversalContactServer,CFGContactServer,ebdgenesys,5130,enabled service description has been added.
16:15:43.808 Trc 20233 LB: status of service ChatServer is 0 (Not active. runMode = Unknown(-1))
16:15:43.808 Trc 20235 LB: Collect service SolutionControlServer data.
16:15:43.808 Trc 20233 LB: status of service ChatServer is 6 (Active. runMode = Primary(0))
16:15:43.808 Trc 20240 LB: service SolutionControlServer has been ignored because its type isn't processed by load balancing.
16:15:43.808 Trc 20235 LB: Collect service StatServerReporting data.
16:15:43.808 Trc 20230 LB: StatServerReporting,CFGStatServer,ebdgenesys,3872,enabled service description has been added.
16:15:43.808 Trc 20233 LB: status of service MCR_EMailServerJava is 0 (Not active. runMode = Unknown(-1))
16:15:43.808 Trc 20242 LB: finish process connections of service WebAPIServer
16:15:43.808 Trc 20200 LB: collecting appications from the root done
16:15:43.808 Trc 20200 LB: establishing connection to LCA...
16:15:43.808 Trc 20233 LB: status of service MCR_EMailServerJava is 6 (Active. runMode = Primary(0))
16:15:43.808 Trc 20200 LB: AdapterML: use LCA port 4999
16:15:43.808 Trc 20233 LB: status of service MCR_UniversalContactServer is 0 (Not active. runMode = Unknown(-1))
16:15:43.808 Trc 20233 LB: status of service MCR_UniversalContactServer is 6 (Active. runMode = Primary(0))
16:15:43.808 Trc 20233 LB: status of service StatServerReporting is 0 (Not active. runMode = Unknown(-1))
16:15:43.808 Trc 20233 LB: status of service StatServerReporting is 6 (Active. runMode = Primary(0))
Connected to LCA, port 4999
16:15:43.808 Trc 20200 LB: +++++++++++++++ AdapterML: OnReconnect
16:15:43.808 Std 20100 LB: ['WebAPIServer' (root application) options].Log.verbose= 'all'
16:15:43.808 Std 20100 LB: ['WebAPIServer' (root application) options].Log.expire= '20'
16:15:43.808 Std 20100 LB: ['WebAPIServer' (root application) options].Log.standard= ''
16:15:43.808 Std 20100 LB: ['WebAPIServer' (root application) options].Log.all= 'WebAPIServer'
16:15:43.808 Std 20100 LB: ['WebAPIServer' (root application) options].Log.messagefile= 'C:\Tomcat\bin\webapimsg.lms'
16:15:43.808 Std 20100 LB: ['WebAPIServer' (root application) options].Log.segment= '10000'
16:15:43.808 Std 20100 LB: ['WebAPIServer' (root application) options].Log.trace= ''
16:15:43.808 Std 20100 LB: ['WebAPIServer' (root application) options].endpoints:101.default= 'Chat inbound queue'
16:15:43.808 Std 20100 LB: ['WebAPIServer' (root application) options].settings.default-char-set= 'windows-1252'
16:15:43.808 Std 20100 LB: ['WebAPIServer' (root application) options].settings.default-code-page= 'Cp1252'
16:15:43.808 Trc 20301 LB: Load balancer instance (SvcDispatcher) initialization done
16:15:43.808 Std 20002 LB: SvcDispatcher - 7.6.100.05, (ebdgenesys, 2020, WebAPIServer)
16:15:43.808 Trc 20200 LB: ConfSrvJavaCommunicator version 7.6.100.01
16:15:43.808 Trc 20200 LB: SvcDispatcher state is 'AVAILABLE'
16:15:43.808 Trc 20300 LB: load balancing servlet initialization done
16:15:43.808 Std 20001 LB: SvcDispatcher servlet - 7.6.100.05, (ebdgenesys, 2020, WebAPIServer)
16:15:43.808 Trc 20233 LB: status of service WebAPIServer is 6 (Active. runMode = Primary(0))
16:18:45.356 Trc 20200 LB: method initializeDispatcher invoked, thread SvcDispatcher
16:18:45.356 Trc 20200 LB: initializeDispatcher: SVC dispatcher has been initialized already, thread SvcDispatcher
16:18:45.356 Trc 20200 LB: received getOwnWebApplication inquiry, thread SvcDispatcher
16:18:45.356 Dbg 09900 (ICC_API i18nsupport, CodePage=Cp1252 CharSet=windows-1252
16:18:45.356 Trc 20501 LB: received service inquiry by type 'CFGChatServer', tenant='Resources' in thread SvcDispatcher
16:18:45.356 Trc 20200 LB: ServiceDescr.getSrvcByType: Tenant=Resources(DBID=101)
16:18:45.356 Trc 20200 LB: ServiceDescr.isTenantAppropriate: Tenant=(101)
16:18:45.356 Trc 20503 LB: dispatched service is ebdgenesys:7007 in thread SvcDispatcher
16:19:32.837 Trc 20200 LB: method initializeDispatcher invoked, thread SvcDispatcher
16:19:32.837 Trc 20200 LB: initializeDispatcher: SVC dispatcher has been initialized already, thread SvcDispatcher
16:19:32.837 Trc 20501 LB: received service inquiry by type 'CFGChatServer', tenant='Resources' in thread SvcDispatcher
16:19:32.837 Trc 20200 LB: ServiceDescr.getSrvcByType: Tenant=Resources(DBID=101)
16:19:32.837 Trc 20200 LB: ServiceDescr.isTenantAppropriate: Tenant=(101)
16:19:32.837 Trc 20503 LB: dispatched service is ebdgenesys:7007 in thread SvcDispatcher[/quote]
Can´t see nothing wrong... :-\
« Last Edit: April 29, 2010, 09:15:56 PM by cavagnaro »
« Reply #7 on: April 29, 2010, 09:23:39 PM »
:o Changed WebApi port to 0 and it began to work!!!  ;D ;D ;D ;D ;D ;D
Now I'm confused about the meaning of that option...
« Reply #8 on: April 30, 2010, 07:18:04 AM »
Hi Cav,
I assume you're talking about the webapi-port option of Chat application... Haven't the port you specified originally been used already by other application?
