" /> Active Flag for Config Objects - Genesys CTI User Forum
Author Topic: Active Flag for Config Objects  (Read 2577 times)
phil
« on: May 05, 2010, 12:35:47 PM »
Hi folks,
where can I find ActiveFlags for configured object in Genesys Databases (7.6). Want to filter all disabled objects.
Cheers
Phil
Re: Active Flag for Config Objects
« Reply #1 on: May 06, 2010, 05:09:25 PM »
  • Hi Phil,
    I assume you're after the attribute "state" in corresponding table (cfg_person, cfg_application etc.)
    phil
    « Reply #2 on: May 10, 2010, 08:06:38 AM »
  • ::) Sure... thought there might be another table including all kind of objects
    « Reply #3 on: May 10, 2010, 09:06:56 AM »
  • Yes, I'm sure :). There is no table holding all type of objects.
    phil
    « Reply #4 on: May 10, 2010, 11:14:55 AM »
  • meant so to say, sure right! cheers
