" /> Field in GAD - Genesys CTI User Forum
Author Topic: Field in GAD  (Read 3529 times)
Offline a.jay
Field in GAD
« on: May 17, 2010, 11:22:26 AM »
Hi all
I have a small problem
I need to add field in the GAD.
The field will allows the supervisor to see the number of the person, with which each operator is talking. If the operator is talking with the certain agency, then in this field should be display the name of the agency.
Re: Field in GAD
« Reply #1 on: May 17, 2010, 03:18:54 PM »
Use of attach data in the strategy?
Offline a.jay
Re: Field in GAD
« Reply #2 on: May 21, 2010, 10:03:44 AM »
Cavagnaro, thanks for your reply
sorry for long waiting
This field for supervisor desktop. How do I make the attach data on specific calls?
Offline Dhanasekar
Re: Field in GAD
« Reply #3 on: June 14, 2010, 09:46:30 AM »
Use Key value pair like,
Key= Agency
Value=AgencyName you can mix with call type or another attached data which you have..
Offline a.jay
Re: Field in GAD
« Reply #4 on: July 01, 2010, 09:48:59 AM »
Dhanasekar thx for your reply
How does what you described can be integrated into GAD?
