" /> Num of ssobjects - Genesys CTI User Forum
Author Topic: Num of ssobjects  (Read 4580 times)
Daizo Yamane
Num of ssobjects
Anybody knows how to count ssobjects?
Akiko Negishi
Num of ssobjects
  • Dear Mr. Yamane,
    the number of ssobjects consists of the total number of the following objects:
    1. items registered under the switch
    2. agent/place groups
    3. number of CME/CCP used
    4. userdefined statistical groups used by router
    5. virtual grouping
    I am not sure how correct this information is, but we use it ourselves to calculate the total number of license required.
    Akiko
    Daizo Yamane
    Num of ssobjects
  • Thanks, Akikosan. I confiemed this and got new Infomation.
    Num of ssobjects = AgentDN+RP+Queue+Agent+AgentGroup+PlaceGroup
    New Statserver doesn't check it. So we don't need to count ssobjects.
    Akiko Negishi
    Num of ssobjects
  • Dear Mr. Yamane,
    do you know starting from what version does statserver no longer check the ssobject license?
    Thank you and I am sorry if I provided you with misleading information.
    Akiko
