" /> Discussion Forums - Genesys CTI User Forum
Author Topic: Discussion Forums  (Read 3432 times)
Ritchie
Discussion Forums
Hi Guys, this is the first Newsgroup that I've seen for Genesys products. Pretty cool. Do you know of any others? Its would seem that Genesys is pretty badly supported outside the company, compared to Microsoft, Cisco, Avaya, etc...
Cheers,
R
Marked as best answer by on Today at 02:32:41 AM
luis
Discussion Forums
  • Undo Best Answer
  • Can your tell me the adress for other forum groups? (cisco, ..)
    thanks
    Ritchie
    Discussion Forums
    If you just use your local ISP newsgroup server and search for cisco or lucent, you will find plenty. Not so with Genesys though :(
