" /> Hyperion - Genesys CTI User Forum
Author Topic: Hyperion  (Read 1954 times)
Offline Adam G.
  • Still Gorgeous.......
Hyperion
« on: October 14, 2010, 09:00:12 AM »
Hi All,
It's no secret that I love Hyperion  ;D ;D
I'll soon be starting to play with Oracle Business Intelligence 11 - as this is what I believe is the latest name\version. I'm looking forward to it! Has anyone else looked at it? Any thoughts\tips etc?
W yn
tony
Re: Hyperion
« Reply #1 on: October 15, 2010, 10:34:37 AM »
I have some thoughts... but they are based on the fact that you just said you love Hyperion... lol ;)
Offline CTIgem
Re: Hyperion
« Reply #2 on: November 01, 2010, 08:00:04 PM »
Sounds like you are the best person to ask about Brio.
I'm having a trouble displaying 17 digit number (hex-connid-id converted to decimal) in brio result.
Brio chops it off around 14 digits or so...don't remember exactly.
Is there a setting that increases max number of display?
I used number format of ################ (17) but without any luck...
Thanks.
tony
Re: Hyperion
« Reply #3 on: November 03, 2010, 05:31:06 PM »
Try this: but you need to be in your Query Results section:
Navigate to the Right of your [i]Result [/i] columns - beyond the last column, then right-click and select  [b]"Add computed item[/b]"
Give your new Column a [b]Name[/b]
Click in the [b]Definition[/b], then click on the [b]Reference [/b] button, on the right.
Select your converted HEX "integer" Field and it will be inserted in the [b]Definition [/b] Field.
Click on the [b]Options [/b] button, on the right and a subsequent Option drop-down list appears, below the Definition Field, called [i]Datatype [/i] - select [b]String[/b], then click [b]OK[/b]
- et voila...! ?
TT
« Last Edit: November 03, 2010, 05:33:47 PM by Tony Tillyer »
Offline CTIgem
Re: Hyperion
« Reply #4 on: November 04, 2010, 02:15:50 PM »
Thanks!!!
Yep, I have to use string type not number...
