" /> CCPulse last hour statistics - Genesys CTI User Forum
Author Topic: CCPulse last hour statistics  (Read 2352 times)
Offline PFCCWA
« on: October 15, 2010, 04:03:30 PM »
I am using a sliding, lasthour profile to capture statistics in a ccpulse template, for the last hour.  However I want this to update on the hour (1 PM, 2 PM, 3 PM) rather than at 40 minutes past which it is doing.
For example I am using the call answered stat :
sensitivity : 1
interval type: sliding, lasthour (within cme this is 3600:10)
notification: 3600
notification mode: time based.
WA
Offline Dionysis
Re: CCPulse last hour statistics
« Reply #1 on: October 16, 2010, 06:25:15 AM »
A sliding time profile is constantly updating, what you have should give you the last 60 minutes, it does not reset every hour.
A growing profile will reset every x time.
So what you want is a growing profile starting on the hour and adding an hour:  0:00+1:00
