" /> Composer Backend Block - error - Genesys CTI User Forum
Author Topic: Composer Backend Block - error  (Read 2654 times)
Offline CTI-traveller
« on: October 19, 2010, 03:55:47 PM »
Hi All,
I'm using back end block in composer 8.0.301.
After entry block, I used DBData block to get the data from my DB. The result is string include stoke. (e.g abc=123/def=456/ghi=789). Then I passed this string to back end block and want to split. My code inside back end ASPX file is as follow:
public override JObject PerformLogic(JObject state, Hashtable additionalParams)
JObject result = new JObject();
String numString = ((JToken)state["Var20"]).ToString();
String st1[] = numString.Split('/');
result = new JObject(new JProperty("Var21", st1[0]),
new JProperty("Var19", st1[1]));
return result;
Then I got error in line ( String st1[2] = numString.Split('/') Who can correct me please? Is it something wrong that I'm just using string split function inside my aspx code??
CN
Online René
Re: Composer Backend Block - error
« Reply #1 on: October 19, 2010, 03:57:52 PM »
What kind of error do you get? Could you post here stack trace of the error?
