" /> WebService block in Compoer - got Http 500 error (bad fetch) - Genesys CTI User Forum
Author Topic: WebService block in Compoer - got Http 500 error (bad fetch)  (Read 6654 times)
Offline CTI-traveller
« on: November 08, 2010, 04:07:18 PM »
Hi All,
I 'm using composer version 8.03 and inside my call flow, I used web service block to call web service. When I tested with web service explorer in composer, it works. But  when I run call flow, i got bad fetch error and inside MCP log, I saw http 500 error.
There is no proxy in the server which web service is located. And my vxml file and webservice is located on the same server. And also I can call this web services from browser. Any idea are appreciate. thanks.
Regards,
CTIT
Re: WebService block in Compoer - got Http 500 error (bad fetch)
« Reply #1 on: November 10, 2010, 12:08:17 PM »
Your issue may be caused by missing library or wrong version of a library that is required by the code generated by Composer. It would be good to check web server log and find out more details about HTTP 500 error.
« Reply #2 on: November 11, 2010, 04:06:03 PM »
Hi R,
Thanks for the reply. I find out the exception in event viewer.
Exception :[color=red] HttpCompileException
Exception message : C:\inetpub\wwwroot\WebServiceTest\include\getWebServiceData.aspx(7);error CS0246: The type or namespace name
'NewtonSoft' could not be found(are you missing a using directive or an assembly reference?)[/color]
At line 7 in my call flow, there is import declarative for Newtonsoft.json as follow.
[color=red]<%@ Import Namespace="Newtonsoft.Json" %>[/color]
Let me explore the layout of my servers and call flow. The composer is located in server-A. There is no IIS.
After validation and generate code, I export the call flow as mention in composer 8.03Help. Then copy this exported folder to server-B.
MCP and IIS7 are there. I created virtual directory in IIS and pointed to the folder(i.e. exported call flow folder)
And Newtonsoft.Json.dll is inside bin folder.  But what I suspect is Genesys recommend to install IIS for composer but in my server-A, there is no IIS. So the call flow is not compile properly and it make the exception. Am I right?
Or if you see there is other hypothesis, please let me know.
CN
« Reply #3 on: November 16, 2010, 04:13:43 PM »
Hi All,
Any opinion??  Someone encountered before??
Regards,
CN
« Reply #4 on: November 16, 2010, 05:01:21 PM »
Hi CN,
It seems the documentation is wrong as it's necessary to add Composer's project to IIS as new application instead of virtual directory.
