" /> Genesys T-Server compatibility with AACC 6.0 (Avaya Aura Contact Center) - Genesys CTI User Forum
Author Topic: Genesys T-Server compatibility with AACC 6.0 (Avaya Aura Contact Center)  (Read 6294 times)
Offline NN1
Hi All,
I am looking for an official statement from Genesys mentioning the T-Server Support with the latest AACC 6.0 (Avaya Aura Contact Center), but I coudn't find any indication at all.
Can anyone tell me if you have any official document mentioning this compatibility ?
Thanks & Regards
Nick
Offline Alexander
Re: Genesys T-Server compatibility with AACC 6.0 (Avaya Aura Contact Center)
« Reply #1 on: December 10, 2010, 10:12:39 AM »
You have to consult the "Supported Media Interfaces Reference Manual".
The last version available (80g_ref_smi_11-2010_v8.0.001.44) does not list it, so it is not officially supported.
Offline 6rlopez
« Reply #2 on: February 21, 2011, 01:17:24 PM »
Hi Nick,
Did you finally get an official answer from Genesys?
Offline craigr
    • My blog
« Reply #3 on: February 25, 2011, 04:58:30 PM »
Do you mean Avaya Aura Contact Center which is more of a Genesys competitor or Avaya Communication Manager (ACM) 6.0? If it is the later I don't think you will have any problems since T-Server integration is via AES. However, in an ACM 6.0 configuration you may have SIP integration problems as SES in no longer supported on ACM 6. Its replacement (Avaya Session Manager) is not currently planned to be tested with Genesys SIP server (according to Genesys support ....)
