" /> Not Ready Reason Code Status Time - Genesys CTI User Forum
Author Topic: Not Ready Reason Code Status Time  (Read 3457 times)
Offline genecool
« on: October 04, 2011, 02:32:53 PM »
I try to display in CCPulse the "Break Time", "Trainning Time" or any other duration for any other reason of not ready status.
I have create action codes from Genesys Administrator and several filters into the Statistics Server.
For example :
Filter "BREAK" :  PairExist("ExtensionReasonCode", "1")
Then, I use this filter with statistic "Total_Not_Ready_Time".
Although I can see into StatServer logs that reason changes, no statistic appears...  :(
[quote]2011-10-03 13:22:05> Server: Switch 'SIP_Switch'->'EventAgentNotReady'
TimeStamp '2011-10-03 13:22:04'
ThisDN '8803'
Agent LoginID '1813'
Reasons
'Break' '1'
Extensions
'AgentSessionID' '03AM81153169P5PF720HM9SUH800001C'[/quote]
Could you help me please ?
Re: Not Ready Reason Code Status Time
« Reply #1 on: October 04, 2011, 07:39:13 PM »
You filter should be:
PairExist("Break", "1")
Offline genecool
« Reply #2 on: October 04, 2011, 08:17:12 PM »
thank you very much, it works  :D
