" /> FlexLM in HA - Genesys CTI User Forum
Author Topic: FlexLM in HA  (Read 6084 times)
Offline ExodusSS
FlexLM in HA
« on: October 13, 2011, 08:13:21 AM »
Hi people!  ;D
I have just raised an SR with Genesys to ask them if there are any licensed components in v7.6 which cannot use the "-l PORT@HOST;PORT@HOST" command line reference - basically referencing 2 instances of the License Server.
Has anyone come across a Genesys component which cannot accept a dual reference to the FlexLM license file?
Thanks!
ESS
PS: I reviewed this post:
http://www.sggu.com/smf/index.php/topic,4961.msg22073.html#msg22073
- but it doesn't highlight any potential issues with any Genesys components using this method and I have been advised that it is possible that CTI Toolbars (using AIL) might run into issues, as well as some of the core Genesys Server Applications...
« Last Edit: October 13, 2011, 08:50:10 AM by ExodusSS »
Offline borkokrz
Re: FlexLM in HA
« Reply #1 on: October 14, 2011, 07:11:48 PM »
Check Genesys Integration Server Release Notes - in early versions from 7.6 release (and 7.2) there was a bug causing correct license release and all license consumption in the result, if 2 GIS instances were using the same pool of licenses. If I remember correctly - you need at least 7.6.300+.
Offline ExodusSS
Re: FlexLM in HA
« Reply #2 on: October 15, 2011, 08:19:49 AM »
Thank you - I'll check it out.
ESS
Offline ExodusSS
Re: FlexLM in HA
« Reply #3 on: October 18, 2011, 02:43:34 PM »
Apparently, there are no issues with FlexLM HA for any Genesys components above 7.6... :)
So, my next question is....
I have an [b]HA-enabled[/b] DEV License File, located on a single Server.  It says on the bottom of the License File that I can update the HOST and PORT in the License File header - but can I use a [i]copy [/i] of the License File and update the HOST and PORT and use it on my second Server (where I would like to run a second instance of the FlexLM daemon) for my HA configuration?
Or do I need to go back to Genesys and ask for 2 x License Files for an HA deployment... even though the License File is clearly an HA version...?
Ta!
ESS
Re: FlexLM in HA
« Reply #4 on: October 18, 2011, 02:56:46 PM »
I think the second option is the one T...I also have all the needed for HA and they sent me 2 license files for 2 different servers which I provided
Offline fnunezsa
Re: FlexLM in HA
« Reply #5 on: October 18, 2011, 03:23:23 PM »
that's the way it works with licensing, you'll get 2 "identical" license file pointing to different volume IDs (hard disk vol ID), one for each license server
Offline ExodusSS
Re: FlexLM in HA
« Reply #6 on: October 18, 2011, 03:50:37 PM »
Yup - just had it confirmed that the guys here were hiding the (2) new License Files... lol
Re: FlexLM in HA
« Reply #7 on: October 18, 2011, 04:28:10 PM »
The precious! Mine!!!
Lol
Offline ExodusSS
Re: FlexLM in HA
« Reply #8 on: October 18, 2011, 06:26:12 PM »
Was quite funny - I was busy trying to work out how to convert 1 old license file to 2 new servers (was NEVER going to work!)  and then someone "remembered" that he was sent both HA License files last week.....
...no names! lol
Offline orazio
Re: FlexLM in HA
« Reply #9 on: October 19, 2011, 09:03:05 AM »
;D
:o
Did you check  your mail-box before writing ??
I can sell a couple of license files.
Offline ExodusSS
Re: FlexLM in HA
« Reply #10 on: October 19, 2011, 10:09:41 AM »
I got them sent to me "free" :P
