" /> GIM purge parameter "days-to-keep-gidb-facts" not working properly. - Genesys CTI User Forum
Author Topic: GIM purge parameter "days-to-keep-gidb-facts" not working properly.  (Read 3413 times)
Offline kevinwang
Hi, Guys,
I set parameter days-to-keep-gidb-facts 200, and like today is June, 18 2011, but records after Apr, 18, 2011  in table GIDB_G_CALL_V were purged after I run Job_Maintain.
similar issue happened to parameter days-to-keep-gim-facts.
Is there any other parameters that affect GIM DB purge?
Thanks in advance.
« Last Edit: February 13, 2012, 02:36:16 PM by kevinwang »
Offline fnunezsa
Re: GIM purge parameter "days-to-keep-gidb-facts" not working properly.
« Reply #1 on: February 14, 2012, 03:17:28 PM »
From GIM 8 Deployment Guide:
days-to-keep-gidb-facts=14
days-to-keep-gim-facts=400
days-to-keep-active-facts=600
days-to-keep-discards-and-job-history=600
purge-transaction-size=100000
purge-thread-pool-size=32
For partitioned Oracle databases only:
partitioning-interval-size-gidb=
86400
partitioning-interval-size-gim=
604800
partitioning-ahead-range=14
You should take a look at that document as it explains how GIM purging works
