" /> How to Enable G729 Codec in MCP - Genesys CTI User Forum
Author Topic: How to Enable G729 Codec in MCP  (Read 3950 times)
Offline Genesys123
« on: August 05, 2012, 10:41:36 AM »
I need to enable G729 codec in MCP.
If I add G729 mcp.Codecs option it is giving me an error.
Logs
[b]2012-08-04T15:28:17.328 Std 46001 WARN 00DB0101-10006E29 4872 0B400BBA Cannot transcode from 5 (g729) to 13 (l16)
2012-08-04T15:28:17.328 Std 38001 EROR 00DB0101-10006E29 2428 02F007D1 A Connection Error has occurred:
2012-08-04T15:28:17.328 Std 33008 EROR 00DB0101-10006E29 2768 028007D2 Media error detected; terminating call[/b]
Offline Timur Karimov
Re: How to Enable G729 Codec in MCP
« Reply #1 on: August 05, 2012, 10:32:00 PM »
Hi
you need also check you gate side config and disable unsuported l16 on it.
HIH
WBR Tim
Offline Genesys123
« Reply #2 on: August 06, 2012, 02:26:43 AM »
Thanks for your reply. Avaya Team told that Genesys side need to enable ,it has been enabled on Avaya side.
« Reply #3 on: August 06, 2012, 03:13:17 AM »
Be aware of the issues G723 can bring...more compression means more CPU, less accurate DTMF, noise increase...not very good for IVR
Offline Genesys123
« Reply #4 on: August 06, 2012, 06:39:47 AM »
Thanks for your valuable input. any idea how to enable g729 in MCP. if i simple add g729 under mpc it is not allowing me to reach IVR.
I guess somthing i am missing in MCP option.
Thanks in advance.
« Reply #5 on: August 06, 2012, 06:55:29 AM »
Erm..check your logs...SIP ones, check the codec negotiation and analyze it
