" /> Genesys Reporting Solution Poll - Genesys CTI User Forum
Poll
What Reporting Solution are you Using?
CCAnalyzer
3 (25%)
Infomart
2 (16.7%)
CCAnalyzer/Informart
6 (50%)
Internal Data Warehouse
0 (0%)
Other
1 (8.3%)
Total Members Voted: 12
Voting closed: November 08, 2012, 08:31:20 PM
Author Topic: Genesys Reporting Solution Poll  (Read 6731 times)
Offline PFCCWA
« on: October 11, 2012, 08:31:20 PM »
I am interested in knowing what customers use as their Genesys Reporting Solution.
We have used CCAnalyzer from its inception and continue to do so.
However there is now a demand for call level detail reporting, which CCA cannot provide.
Do we go for InfoMart or an Internal solution I wonder...
Re: Genesys Reporting Solution Poll
« Reply #1 on: October 11, 2012, 10:44:31 PM »
Remember we can use CCA AND InfoMart..make it a multiple choice
« Reply #2 on: October 12, 2012, 06:24:20 AM »
Yes, I agree with Cavagnaro. For customers who have got R8.0+, we install often both solution CCA and InfoMart. I would be more interested in what applications do you use to browse the reports - Hyperion/Brio,Crystal Reports,BOE,own solution,..?Maybe I create new poll..
Offline Adam G.
  • Still Gorgeous.......
« Reply #3 on: October 12, 2012, 08:24:45 AM »
There is also a better soluion on the way ;-)
« Reply #4 on: October 12, 2012, 08:37:21 AM »
Better solution..? Tell me/us more,please..
Offline PFCCWA
« Reply #5 on: October 12, 2012, 09:57:40 AM »
thanks for the response guys
have reset the poll with a combined CCA/InfoMart option.
We have asked for an infomart quote...
Offline Adam G.
« Reply #6 on: October 12, 2012, 10:46:30 AM »
[quote author=Kubig link=topic=7462.msg31956#msg31956 date=1350031041]
We have a Big Data based reporting solution available shortly - designed to replace both CCA and Infomart - there are other new functionalities avialable in it as well.
« Reply #7 on: October 12, 2012, 11:11:09 AM »
This looks good, but just do not know how to use it currently is and if it is not called overkill.See in future..
Offline Timur Karimov
« Reply #8 on: October 12, 2012, 12:07:24 PM »
[quote author=Pavel link=topic=7462.msg31958#msg31958 date=1350038790]
replace both...it's a good. But , IMHO, what we really need - solution to replace CCPulse
« Reply #9 on: October 12, 2012, 12:40:06 PM »
Why do you need replace CCPulse+?
Offline Adam G.
« Reply #10 on: October 12, 2012, 02:19:23 PM »
[quote author=Timur Karimov link=topic=7462.msg31960#msg31960 date=1350043644]
[quote author=Pavel joined Avaya team link=topic=7462.msg31958#msg31958 date=1350038790]
It has a real-time reporting capability  :)
« Reply #11 on: October 16, 2012, 11:37:46 AM »
[quote author=Kubig link=topic=7462.msg31961#msg31961 date=1350045606]
Coz it's ugly, unfriendly, solid, incompatible, moth-eaten piece of ....
But at the same time  - now it's only one front-end with real-time capabilities.
WBR
« Reply #12 on: October 16, 2012, 12:08:06 PM »
[quote author=Timur Karimov link=topic=7462.msg31980#msg31980 date=1350387466]
WBR
I do not think so,that the CCPulse app is ugly,unfriendly,etc...It is quite a powerful tool,if anyone can work with it and use all functions. So,from Genesys is only one front-end app for real-time,but you can write/develop your own app. Do you think,that your app will be better then CCPulse? What would you like to improve?
Offline Daimonas
  • There's a fish in every bowl.
« Reply #13 on: October 17, 2012, 10:46:57 PM »
CCPulse needs some improvements, is almost as old as datamart. I think it will eventually be replaced, but it is what it is. One big improvement would be to modify existing workspaces, without having to recreate all the views when you create new objects.
As a work around, I leave my CCPulse open when I create new objects, so they can be quickly added without having to create a new view ;D
