" /> Filters for CCA - Genesys CTI User Forum
Author Topic: Filters for CCA  (Read 6828 times)
Zygis
Filters for CCA
I need information about filters for CCA, in my CC are to 2 services (agent groups), one agent and more can answer the calls for both groups. I have to get statistics about every services, how much per day agents talk for this group and another. I create filter in DMA, in CM I create "annex", in routing strategy add new topic "UPDATE= name=Customer, value= "agent group name"". Thats all.
And than I with CCA want to get statistic in this table is always zero.
Q. There are My mistake? and what I have to do?
Thanks.
JohnR
Filters for CCA
I've never tried filtering off of data attached in a routing strategy, but it should work. You mention that you use "update" in the routing strategy, I believe you should be using "attach" to add a key value pair to filter on. The filter would then be in the form PairExists("key","value")
As an alternative, you could try setting up a filter on an existing call attribute, such as "ThisQueue = "7113"" or "ThisDINS = 6113".
Marked as best answer by on Today at 08:00:30 PM
Filters for CCA
  • Undo Best Answer
  • Have you defined the right filters in DMA?
    I was able to successfully get it to work with URS attaching the data to the call, and then have CCA tell me how many calls came with a specific key value. I use this when I want to create a routing report for a multiskill agent.
    Zygis
    Filters for CCA
    hallo,
    Thanks, I'll try it.
    Zygis
    Filters for CCA
    Hallo,
    Can you explain for what is mean "URS"? in the documentation I didn't find about it.
    Zygis
    Filters for CCA
    Thanks for all, now this filter working in my system.
    Bye
    Filters for CCA
    What did you change?
    Zygis
    Filters for CCA
    In routing strategy insert new topic "Attach" and after that topic "update". My filter was created without mistake.
    Zygis
