" /> Switch Simulator - Genesys CTI User Forum
Author Topic: Switch Simulator  (Read 4400 times)
Ralph
Switch Simulator
Hi there,
if anybody has a good Switch Simulator (Software only) or knows a resource where to buy one, please post!
Thanks. Ralph
Mark Newcomb
Switch Simulator
  • Genesys always used to be able to supply one generally for free.........have you asked them?
    Ralph
    Switch Simulator
  • Well, I do have the generic Lucent G3 PBX SwitchSimulator.
    Does anybody know about a documentation for that piece of software? Eg.: There is a switchserv.cfg file defining ports and there seems to be a p [value] comamnd line arg given in the batch file to start SwitchSim. Any idea about it?
    What specifically do I have to configure in TServer for Lucent G3 to connect to the simulator. Does anybody have a document on this?
    Sidney Orret
    Switch Simulator
  • Hello Ralph
    Could you send me a copy of the simulator? If yes, please use
    sidney.orret@verizon.net
    Switch Simulator
  • Hi, Ralph,how are you?
    I have checked and you can DL the latest PBX simulator manual of support.genesyslab.com. It is not that great, but it tells you pretty much everything you need to know.
    Tell me if you had trouble finding it!
