" /> hold issue - Genesys CTI User Forum
Author Topic: hold issue  (Read 2716 times)
Offline prempreet
hold issue
« on: February 11, 2013, 05:32:31 AM »
I are facing some problem in extension/trunk on which record parameter is enable.When I call from extension on which recording parameter is enabled then a hold warning appears on yealink phone when we pick up the call.The hold appears for 1 second after that we can able to hear voice,but for that 1 second there is no voice.
Please help me to resolve with issue.
Regards
prem
Re: hold issue
« Reply #1 on: February 11, 2013, 07:50:53 AM »
So,it is so difficult to say what is the cause of issue when you did not posted any description about your troubleshooting. It caused by many reasons and it is necessary to check T-Server logs and logs of components at "way" of call.
Re: hold issue
« Reply #2 on: February 11, 2013, 12:29:34 PM »
I will not check your logs,this is your job :-) I am only asking if you do something in troubleshooting and if yes,what do you want discover? So,I do not know if the SIP logs covering the issue,I recommended to make a network sniff and do troubleshooting there.
Offline prempreet
Re: hold issue
« Reply #3 on: February 12, 2013, 04:13:06 AM »
Ok,the only troubleshooting is did is that when i disabled the recording on trunk or extension then no hold message is shown but when i enablete recording then hold message is appear on extension when we answer a call.
Actually i am new to genesys so i can't able to find any errors in Logs.
I am using yealink phones and same hold msg comes in yealink phone but when i am using any another phone hold message is not showing but i hear voice after 1 sec delay.
So,suggest me any solution for this.
Re: hold issue
« Reply #4 on: February 13, 2013, 12:42:12 PM »
Recording on Trunk or on Agent DN? You must decide one of them, as recording acts a 3rd party on the conversation. Maybe this component is taking too long to answer...check you configuration and logs. Check deployment guide for both scenarios.
