" /> Interaction Workspace - Media errors codes - Genesys CTI User Forum
Author Topic: Interaction Workspace - Media errors codes  (Read 21176 times)
Offline dimm
« on: September 09, 2013, 07:20:00 PM »
Hi, does anybody have an information about "media error" codes in IWS application?
My users reporting errors and it looks like "media error (58)" or "media error (%digits_here%)". Sometimes there is also a message near this error, but most of errors are just with digit codes. How to figure out with this codes?
[img]http://habrastorage.org/storage3/f6b/047/d2a/f6b047d2a82628524144a98fa1d0ef41.jpg[/img]
Tried to speak with google on Genesys forum and the only thing I found was TServer error codes (there were not so much codes + there were no codes I've experienced).
Re: Interaction Workspace - Media errors codes
« Reply #1 on: September 09, 2013, 07:20:36 PM »
Check TServer logs as well.
Offline dimm
« Reply #2 on: September 09, 2013, 07:23:57 PM »
This is what I found http://docs.genesyslab.com/Documentation/TS/8.0.0/TSCSTA/CSTAErrorMessages
But it's not what I'm looking for or contains incomplete information :-\
« Reply #3 on: September 09, 2013, 07:48:46 PM »
Well as said, you need to check TServer logs, the message is that, an indication of something going wrong, if you expect a log to say: Hey! User 1000 just unplugged his computer! Go check him! or "Hey network link is slow as hell, the cause is the change you did last night on the switch named swt001001 with IP address x.x.x.x. Revert to this config"....then you are living on a dream world. Each event can have many possible causes and you as trained engineer for support should be able to trace that error and analyze your platform and environment.
« Reply #4 on: September 10, 2013, 06:20:16 AM »
As Cav said...check logs, check logs and again check logs :-)
Offline mikepike
« Reply #5 on: January 07, 2014, 03:38:31 PM »
Hi Dimm,
Did your user log in an IP phone before ?
Offline genesysguru
    • Genesys Guru Blog
« Reply #6 on: January 07, 2014, 05:24:25 PM »
Yup - these errors call come from T-Server events so that is the first place to check.
