" /> Error in InfoMart logs - Genesys CTI User Forum
Author Topic: Error in InfoMart logs  (Read 2488 times)
Offline paraveen
« on: September 25, 2013, 02:19:40 PM »
Hi I See in OUR INFOMART log files as
“party ignored, number of objects for ixn > 1500” message?
“PARTYinfo ignoring source row with bad data during transformation: unexpected exception processing data for this Party (0002Ha8P6UHE2TU0-0000000000-00000000000049018965) : java.lang.NullPointerException” message.
What does it mean?
Offline Flávio
Re: Error in InfoMart logs
« Reply #1 on: October 01, 2013, 11:03:01 AM »
Hi, what is your GIM version?
after a quick look i found these:
Root Cause:
Java is running out of memory due to a  large number of MM interactions affected by bogus routing strategy (> 300 parties)
GIM prior to 7.6.014.09 is susceptible to out-of-memory caused by VQ, not just by G_PARTY data.
Solution:
Upgrade to latest version of GIM.
- set –Xmx1400m (or lower dependent on other application memory usage).
- set -XX:GCTimeRatio=4.
- set transformation-buffer-size=1.
cheers,
