" /> GVP8 general question - Genesys CTI User Forum
Author Topic: GVP8 general question  (Read 2955 times)
Offline CK
« on: February 05, 2014, 07:54:54 AM »
Is there any chance that the IVR application will not be executed in case of numerous simultaneous calls to it? I am not using VTPs, I am in GVP 8. My Maximum Concurrent Sessions is set to no limit (blank) for the IVR profile being used.
How to handle such an issue? I can only think of a strategy modification when it exits from the red exit on the Play application block. Any ideas?
Re: GVP8 general question
« Reply #1 on: February 05, 2014, 08:07:31 AM »
Of course it is possible. You have to specify how much "channels" have each LRG within GVP configuration. The default value from the RM is used, if this parameter on LRG level is empty.
Offline CK
« Reply #2 on: February 05, 2014, 08:29:43 AM »
You are right, I missed that... Thanks Kubig
Is there a way to monitor how many ports are being used?
« Last Edit: February 05, 2014, 08:49:59 AM by CK »
« Reply #3 on: February 05, 2014, 09:19:55 AM »
You can find out this information in SIP server log, where you can find SIP NOTIFY messages, which contains currently count of used ports and total ports number. I do not know about another way and I mean that no other way exists yet.
Offline CK
« Reply #4 on: February 05, 2014, 09:23:05 AM »
Thank you very much!
« Reply #5 on: February 05, 2014, 09:24:21 AM »
You're welcome
Offline mduran22
« Reply #6 on: February 05, 2014, 05:32:32 PM »
You should be able to monitor the number of active channels through EMS.
