" /> Setting no-answer-overflow from strategy? - Genesys CTI User Forum
Author Topic: Setting no-answer-overflow from strategy?  (Read 1909 times)
Offline msh
« on: March 25, 2014, 11:21:59 AM »
Hi
Is it possible to set no-answer-overflow from a routing strategy? I would like to avoid setting it on each agent login (We need to have different routepoint for different agents).
I have tried SetCallOption['no-answer-overflow','XXXX'] in a function box in the strategy but it does not seems to have any effect. It does not appear in the log files.
We are using SIP server 8.
Re: Setting no-answer-overflow from strategy?
« Reply #1 on: March 25, 2014, 12:40:20 PM »
Try to set them as an Extension data
