" /> Can two t-servers connect to same switch? - Genesys CTI User Forum
Author Topic: Can two t-servers connect to same switch?  (Read 2394 times)
Offline Iphoneuser
« on: April 08, 2014, 03:23:21 PM »
Hey folks, wondering whether this is possible or not
two t-servers which are located in different tenants say tserver1 in xtenant and tserver2 in ytenant, can they connect to same switch using the tcp ip link?
Re: Can two t-servers connect to same switch?
« Reply #1 on: April 08, 2014, 04:04:26 PM »
Yes as long as they don't monitor same objects on the Switch (PBX)
Offline Fra
« Reply #2 on: April 09, 2014, 08:31:58 AM »
It depends on the switch: some don't support switch partitioning.
Fra
