" /> Stat Server WarmStandby - Genesys CTI User Forum
Author Topic: Stat Server WarmStandby  (Read 4346 times)
Offline kerry.finlayson
« on: January 16, 2015, 12:58:33 PM »
Hey folks,
I am building a third party app which registers and opens a number of statistics.  I have implemented the warm standby connection to my stat servers but I am having some issues.  I am registering for a number of stats and when the stat servers are failed over I get an event to advise me this has happened but I don't automatically receive any updates on the registered stats.  Now I am finding it difficult to get any information on whether in a warm standby situation the failed over stat server has details of the stats which we registered against?  Should I expect that I should still have registrations against statistics for my app?
I was under the impression that in a warm standby scenario both servers would have knowledge of the connections and registered stats or do I need to go and re-register on the failed over server?
This is my connection code:
private void Connect()
            try
                PropertyConfiguration conf = new PropertyConfiguration();
                conf.SetOption("protocol", "addp");
                conf.SetOption(AddpInterceptor.TimeoutKey, "10");
                conf.SetOption(AddpInterceptor.RemoteTimeoutKey, "10");
                conf.SetOption(AddpInterceptor.TraceKey, "both");
                Endpoint primaryEndpoint = new Endpoint(_statServerName, _statServerPrimaryHostName, _statServerPrimaryPort, conf);
                Endpoint backUpEndpoint;
                if (_statServerSecondaryHostName != "")
                    backUpEndpoint = new Endpoint(_statServerName, _statServerSecondaryHostName, _statServerSecondaryPort, conf);
                else
                    backUpEndpoint = new Endpoint(_statServerName, "", _statServerPrimaryPort, conf);
                    TpsLogManager<StatisticQueryEngine>.Error("Error : StatsQueryEngine - " + _statServerName + " Backup is blank");
                    _managementServer.SendMessageToMessageServer(97014, LogCategory.Alarm, LogLevel.Alarm, "Error : StatsQueryEngine - " + _statServerName + " Backup is blank");
                statServerProtocol = new StatServerProtocol(primaryEndpoint)
                    ClientId = _statisticRefId,
                    ClientName = _clientName,
                statServerProtocol.Closed += statServerProtocol_Closed;
                var warmStandbyConfig = new WarmStandbyConfiguration(primaryEndpoint, backUpEndpoint)
                    Timeout = 5000,
                    Attempts = 2
                var warmStandby = new WarmStandbyService(statServerProtocol);
                warmStandby.ApplyConfiguration(warmStandbyConfig);
                warmStandby.Channel.Opened += Channel_Opened;
                warmStandby.Channel.Closed += Channel_Closed;
                warmStandby.StateChanged += warmStandby_StateChanged;
                warmStandby.SwitchedOver += warmStandby_SwitchedOver;
                warmStandby.Start();
                warmStandby.Channel.BeginOpen();
                _eventBrokerService = BrokerServiceFactory.CreateEventBroker(statServerProtocol);
                TpsLogManager<StatisticQueryEngine>.Debug(_statServerPrimaryHostName + " :Statistic broker service created");
                _eventBrokerService.Register(OnEventInfo);
                TpsLogManager<StatisticQueryEngine>.Debug(_statServerPrimaryHostName + " :Statistic handler registered.");
                //Activate event broker service
                _eventBrokerService.Activate();
                TpsLogManager<StatisticQueryEngine>.Debug(_statServerPrimaryHostName + " :Event Broker Service Activate.");
                TpsLogManager<StatisticQueryEngine>.Info(statServerProtocol.State.ToString());
            catch (Exception e)
                TpsLogManager<StatisticQueryEngine>.Error("Error : StatsQueryEngine : " + e.Message);
I would appreciate any help you can provide and would appreciate if you can see anything in the code above which could be causing my issue.
Thanks in advance,
Kerry.
Re: Stat Server WarmStandby
« Reply #1 on: January 16, 2015, 01:28:07 PM »
Why Warm and not Hot?? On Hot they sync everything. On Warm they sync basic data but the backup is passive until you make it Main
« Reply #2 on: January 16, 2015, 01:37:26 PM »
StatServer does not support pure Hot-Standby mode. Just WarmStandby.
« Reply #3 on: January 16, 2015, 06:47:19 PM »
[quote author=Kubig link=topic=8674.msg38426#msg38426 date=1421415446]
True...my bad :D
Adam G
« Reply #4 on: January 17, 2015, 10:03:31 AM »
Might be the config - or your misinterpretation of how Warm Standby works...
Do your StatServers have connections, as Objects in CIM/CME?
Are they set as Warm Standby's for one another, in CIM/CME?
Check documentation for any other Platform Settings required for Warm Standby of a StatServer.
Test both StatServers on Failover and Failback(with CCPulse+?) to ensure Stats are updating, without your code.
HTH?
AG
« Reply #5 on: January 19, 2015, 12:40:56 PM »
I strongly recommend to configure StatServer with option allow-clients-in-backup-mode (does not know the exactly name of the option) to true => this allows you to connect to the backup statserver too and receive required stats.
« Reply #6 on: January 20, 2015, 12:00:25 PM »
Hi Kubig,
That worked!  ;D
Thanks so much for your help folks, really made my day when this worked.  This has been haunting us for a while.
Kerry.
