" /> Queueing at two seperate VQ's. - Genesys CTI User Forum
Author Topic: Queueing at two seperate VQ's.  (Read 5130 times)
Offline Nathzn
« on: January 31, 2015, 12:55:08 PM »
Hi Guys,
I want to see if this is possible, basically I have a VQ in which the interaction uses. Is it possible to then update another VQ after it gets answered by the agent? For example in my enviroment I'm targeting a store, so after the call is delivered i want to log it another specific VQ (Store Name/Code VQ)
Any help would be appreciated.
« Last Edit: January 31, 2015, 01:03:18 PM by Nathzn »
Adam G
Re: Queueing at two seperate VQ's.
« Reply #1 on: January 31, 2015, 01:09:20 PM »
Queueing[i] at [/i]2 VQ's...
...or Reporting[i] from [/i]2 VQ's..?
Offline Nathzn
« Reply #2 on: January 31, 2015, 01:40:35 PM »
Sorry Adam,
Reporting from 2 VQ's I only need the main one to show queueing.
If that makes sense!
Offline Nathzn
« Reply #3 on: January 31, 2015, 01:52:27 PM »
Is there a possibility of manually updating a VQ?
« Last Edit: January 31, 2015, 02:28:20 PM by Nathzn »
« Reply #4 on: January 31, 2015, 03:10:23 PM »
Not at all...
Maybe if you tell us your real need, I guess you are approaching via the non-best solution around...
Adam G
« Reply #5 on: January 31, 2015, 04:39:30 PM »
My guess...
You want to to Target route to one (VQName1) - but you also want to use an additional (VQName2) to "Report" from, for the same Target(s)?
You can only apply one VQ per Target.  But you can apply multiple Targets...
HTH?
Offline Nathzn
« Reply #6 on: February 01, 2015, 10:18:29 AM »
Thanks very much for your replies.. it looks like this may not be possible.
Adam G
« Reply #7 on: February 01, 2015, 10:51:32 AM »
[quote author=Nathzn link=topic=8698.msg38556#msg38556 date=1422785909]
This [i]should [/i]work:
Create a Target to an [i]empty [/i]Agent Group - apply[b] VQName1[/b]
Set the Target to expand immediately (no wait time), to your [i]actual [/i]Target Group - apply [b]VQName2[/b]
« Reply #8 on: February 01, 2015, 02:08:04 PM »
The problem with that Adam is that if call is abandoned will not report to target 1. For what he says he wants it only when answered...
Adam G
« Reply #9 on: February 01, 2015, 03:38:49 PM »
okay, okay...
2 VQ's associated with 2 Route Points - pass the call through them both...
« Reply #10 on: February 01, 2015, 11:38:35 PM »
Lol same as using different targets.
Offline jamesmurphyau
« Reply #11 on: February 02, 2015, 07:08:19 AM »
Could this help? You can call a subroutine right before agent routing.. You receive the selected target and selected vq details as a input var. You can edit the selected target (passing in the output var), cancel routing, update user data, etc..
Custom Routing
Beginning with release 8.1.2, the new Custom Routing functionality allows automatic splitting of code functionality. This splits target selection of objects into a set of functions (SelectDN, SuspendForDN, RouteCall) under the cover of single target selection object. This allows any code to be put in a strategy between a target selection and routing. Additional code can be inserted before the RouteCall function is provided in the form of subroutine.
Fill in the Custom routing parameter shown in Figure 173 to activate the custom routing functionality.
Adam G
« Reply #12 on: February 02, 2015, 07:32:58 AM »
[quote author=cavagnaro link=topic=8698.msg38560#msg38560 date=1422833915]
Tromboning!
