" /> Genesys Pulse 8.5 - Genesys CTI User Forum
Author Topic: Genesys Pulse 8.5  (Read 3051 times)
Offline raza990
Genesys Pulse 8.5
« on: April 20, 2015, 07:42:38 AM »
Hi All,
Anybody worked on Genesys Pulse 8.5 ?
I have implemented the Genesys Pulse 8.5 and voice stats are working fine but when email stats are not working. May be I am doing something wrong.
Can anyone help me which stat should use for Number Of Waiting Email on virtual queue ?
Regards,
Raza
Re: Genesys Pulse 8.5
« Reply #1 on: April 20, 2015, 07:45:22 AM »
Have you deployed the Java-stats on StatServer for Pulse solution?
Offline raza990
« Reply #2 on: April 20, 2015, 07:49:09 AM »
No, I haven't deployed Java-Stats on Stat Server because I want the email reporting on virtual queue - not interaction queues !!!
« Reply #3 on: April 20, 2015, 07:53:09 AM »
There is no difference between VQ for email and for voice, Pulse is working in same way for both. You can just check the RN , if there are any issue related and make an upgrade. I am using the latest version and all is working as expected.
Offline raza990
« Reply #4 on: April 20, 2015, 08:51:55 AM »
Dumbest thing I've ever done  >:(
Ixn connection was missing in Stat server that was the reason email stats was not working !!!
« Reply #5 on: April 20, 2015, 10:50:14 AM »
Similiar issue should be tricky to find out :)I am glad you have resolved it.
