" /> Composer - Generating Code - Genesys CTI User Forum
Author Topic: Composer - Generating Code  (Read 2271 times)
Offline aravind_mano
« on: July 23, 2015, 09:59:48 AM »
In Java composer project, i have created subfolders under CallFlows. When i Generate the code, the composer does not generates vxml for the callflow files placed under subfolders.
Project structure:
- Callflows
  - Common
    - Errorhandling.callflow (subcallflow)
  - OrderStatus
    - OrderStatus.callflow  (subcallflow)
  - Main.callflow
In src-gen folder, i am seeing only 1 file 'Main.vxml'. Is there any settings to be enabled in order to generate vxml for all callflow files.
Aravind
Re: Composer - Generating Code
« Reply #1 on: July 23, 2015, 10:04:01 AM »
Open them and generate their code. Sub call flows are not generated automatically by main call flow
Offline pattadon
    • Pattadon.com
« Reply #2 on: July 31, 2015, 01:57:54 PM »
I have a same problem that I need to generate every sub call flows    :( :( :(
