" /> Call rejected by the Agent - Genesys CTI User Forum
Author Topic: Call rejected by the Agent  (Read 4617 times)
Offline karthik.keyan007@gmail.co
« on: July 25, 2015, 05:01:16 AM »
Hi Guys,
I have a doubt related to call rejection by the agent. Not sure if its same as RONA setting in SIP Server
Here is the scenario :
Customer call the TFN and gets routed to the agent. Agent is logged in using WDE and auto answer feature is off. The agent rejects the call
What will happen if the agent rejects the incoming call due to some reason ? I want that call to be routed back to the queue so that some other agent belonging to the same agent group answers it . Can you kindly help me with this guys.
Karthik
Offline Tambo
Re: Call rejected by the Agent
« Reply #1 on: August 17, 2015, 09:21:17 AM »
check the TServer / SIP server logs for the reason that the call is rejected at the agent
« Reply #2 on: August 17, 2015, 10:39:12 AM »
Check option "interaction.reject-route" on WDE object. If the value is empty/blank, the WDE/IWS should redirect the call to the same target (RP in general) from which becomes.
« Reply #3 on: August 17, 2015, 02:11:29 PM »
Reject a call? What is that? Transfer it? For calls there is no Reject. Technically speaking it is a Transfer invite, so if you don't accept (Answer) it will be back to the main object that was doing the transfer.
Offline Fra
« Reply #4 on: August 18, 2015, 06:58:49 AM »
[quote author=cavagnaro link=topic=9005.msg40516#msg40516 date=1439820689]
Not really. Technically, especially in SIP, to an INVITE a client can respond with a 603 Decline, which is a proper reject message;
Fra
« Reply #5 on: August 18, 2015, 07:23:25 AM »
In IWS/WDE case, it means RequestRedirectCall on T-Lib level. The topic is about WDE
« Reply #6 on: August 18, 2015, 07:25:59 AM »
Agree with Fra :D my bad
Enviado de meu C6602 usando Tapatalk
