" /> Unable to load strategy in IRD - Genesys CTI User Forum
Author Topic: Unable to load strategy in IRD  (Read 2104 times)
Offline Junaid
« on: July 29, 2015, 03:09:45 PM »
Hi there,
after loading strategy on RP in IRD, it is not loaded (no error prompted). I found in configuration server logs:
15:16:05.318 Std 07002 Execution failure: SQL statement '?', reason '[Microsoft][ODBC SQL Server Driver][SQL Server]Violation of PRIMARY KEY constraint 'PK__cfg_flex__1800E1CC70A8B9AE'. Cannot insert duplicate key in object 'dbo.cfg_flex_prop'. ', error code 5
what does it mean "insert duplicate key" ?
the same error is generating in Configuration server logs while creating new person on CME.
Please advise. Thanks in advance
Regards,
Junaid Hassan
Re: Unable to load strategy in IRD
« Reply #1 on: July 29, 2015, 03:43:19 PM »
You have a problem on your DB. Maybe you tried to do something manually on it. Open an ESR with Genesys or restore a working one
Enviado de meu C6602 usando Tapatalk
