" /> I cannot get my config server's status - Genesys CTI User Forum
Author Topic: I cannot get my config server's status  (Read 3831 times)
Jeff
Dear Genesys gurus, I need your advice. I am installing Genesys 6.5 and have noticed that I cannot see confserv's status in Solution Control Interface. Can someone please tell me why it tells me that my confserv is [stopped] when it is actually running? Should it be this way?
Superglide
  • Jeff,
    Are you running a CSProxy? I cannot even see our config server in our SCI.
    Kevin
  • Look in the documentation, I think the framework deployment guide. I know if you put the following in your dbserver.cfg file, you can see the cfg_dbserver's status:
    [lca]
    lcaport=4999
    I remember reading it in the 6.5 documents, b/c it also goes through setting up redundant cfg_dbservers and confserv's. (It's not as straightforward as it looks).
    Jeff
  • thank you!
    I have added [lca] section to my confserv and now I can see its status in SCI. Why do I have to add it manually? Why was it not part of confserv.conf file? Is there a reason why I would not want to use lca section?
