" /> Change Default config manager password - Genesys CTI User Forum
Author Topic: Change Default config manager password  (Read 7796 times)
nomster123
« on: September 04, 2015, 08:52:34 AM »
due to a stupid mistake i changed password of default by mistake and unable to login to my config manager, im using SQL server 2008 with Conf server 8.1, tried to delete the password from cfg_person but it still doesnt log in as it is uding its own encryption. If i even delete the password entry it still doesnt log in. Suppose there is exncrypted for empty string too.
Please help its very important
Re: Change Default config manager password
« Reply #1 on: September 04, 2015, 10:33:48 AM »
You will have to delete password on sql table and restart CfgServer after that.
Enviado de meu C6602 usando Tapatalk
nomster123
« Reply #2 on: September 04, 2015, 01:47:01 PM »
Deleted password and restarted DB server and CFG server but no use. its not accepting blank password
Marked as best answer by on Today at 11:49:26 AM
« Reply #3 on: September 04, 2015, 02:03:19 PM »
  • Undo Best Answer
  • Then create a password on another account you know. Copy the encrypted value to the default account and done. Easy as that...
    nomster123
    « Reply #4 on: September 04, 2015, 02:09:57 PM »
    Problem is that there is only one account in the DB right now that is default. Havant added any agent yet :/
    Adam G
    « Reply #5 on: September 04, 2015, 02:54:22 PM »
    Re-install?
    « Reply #6 on: September 04, 2015, 03:22:50 PM »
    Just idea : Try to extract just the SQL script for cfg_person table from the SQL scripts for the CFG databse and recreate this table (the default user should be create with default password).
    nomster123
    « Reply #7 on: September 04, 2015, 03:34:00 PM »
    dont want to reinstall, have already installed alot of things in it
    @kubig: ill try this and get back to you on this
    nomster123
    « Reply #8 on: September 04, 2015, 03:51:54 PM »
    Kubig , I am having trouble finding exact SQL statement which will insert  into persons table, There were two scripts i used , one was init other was CFG locals but both contain a lot of commands, it might just affect the whole Table.
    Can you please specify which commands from these two scipts. Forgive me knowledge of SQL. Using SQL Server
    Offline raza990
    « Reply #9 on: September 07, 2015, 07:35:00 AM »
    Please follow below steps if you forget the password of configuration server.
    1. Make a backup of your CME database
    2. Stop Configuration Server
    3. Run this SQL query against the database:
    a. Pre 8.0.3 configuration server/db:
    UPDATE cfg_person SET password='5F4DCC3B5AA765D61D8327DEB882CF99' WHERE dbid=100;
    b. 8.0.3 config server or highter:
    UPDATE cfg_person SET password='5F4DCC3B5AA765D61D8327DEB882CF99' , salted_string=NULL WHERE dbid=100;
    4. Start Configuration Server.
    This will change the password to 'password'.
    NOTE:
    Don’t put the password of your own instead of '5F4DCC3B5AA765D61D8327DEB882CF99'.
    Adam G
    « Reply #10 on: September 08, 2015, 12:36:10 PM »
    Good post.
    Wonder if there is a way on SMF to flag it, as "useful"?
    [quote author=raza990 link=topic=9084.msg40723#msg40723 date=1441611300]
    NOTE:
    orel
    « Reply #11 on: September 02, 2022, 05:02:00 PM »
    I am trying to to compute the correct hash with a given password and salt.
    The documentation states that this should be sha256(clear_text_password || salt) or sha256(salt || clear_text_password) but this doesn't seem to work.
