" /> IWS - Genesys CTI User Forum
Author Topic: IWS  (Read 3613 times)
Offline Leonxxx86
IWS
« on: October 27, 2015, 10:59:11 PM »
-xxxxx is a SIP DN. Look for an already started SIP Endpoint for this DN and Sip Server xxxxxxx
-There is already an IW SIP Endpoint for this xxxxx SIP DN.
Does anyone know what does the above in IWS logs mean? Thanks
Re: IWS
« Reply #1 on: October 27, 2015, 11:35:48 PM »
Pretty obvious
A SIP endpoint already registered that DN
Offline Leonxxx86
Re: IWS
« Reply #2 on: October 27, 2015, 11:51:12 PM »
Thanks for your reply cav, do you mean someone else using the ext on a different computer?
Re: IWS
« Reply #3 on: October 28, 2015, 12:53:03 AM »
Yes
Even you could search the registration event and see ip address
« Last Edit: October 28, 2015, 12:54:54 AM by cavagnaro »
Offline Leonxxx86
Re: IWS
« Reply #4 on: October 28, 2015, 01:54:48 AM »
Thanks, I looked in IWS log and I found:
RegisterDevice  [voice, AgentId:xxx, Switch xxxx]
and
[AgentEvent Begin] EventRegistered AgentID ? State:LoggedOut  [voice, AgentId:xxxxx, Switch xxxx]
There is no Ip address for the resisted devise when I searched the log :-\
Re: IWS
« Reply #5 on: October 28, 2015, 03:39:39 AM »
WHy on IWS log...you should look at SIP Server logs...
Offline Barn5ter
Re: IWS
« Reply #6 on: October 28, 2015, 08:15:18 AM »
Search for "REGISTER sip:" in the SIP logs of SIP Server, not the T-Lib ones.
Offline Leonxxx86
Re: IWS
« Reply #7 on: November 04, 2015, 03:24:40 AM »
Thanks Guys
