" /> Genesys CTI document - Genesys CTI User Forum
Author Topic: Genesys CTI document  (Read 5426 times)
Faisy
Hi Guys
We are planning to implement Genesys solutions to be interfaced with our Avaya G3R... This is an urgent client requirement...
If at all any of u guys will help me finding these documents.....
my email is faisalsaudagar@hotmail.com
Thnx in advance
Faisy
Marked as best answer by on June 05, 2025, 08:43:12 PM
Vivek
  • Undo Best Answer
  • I would recommend you to visit http://www.genesyslab.com/about/contact/sales.html and request for any demo products and documents.
    or call their tech support#8883695555
    Nguyen
    Well, check Genesys CD that you got when you have purchased your TServer there is a folder called documentation. Inside there you will find all the docs you need for your PBX.
    Or, just ask here we would be more than happy to help!
    John Doe
    Hi F,
    Can I recommend you invest in some Genesys training and hire some experianced Genesys techies to help you. It's not as easy as you think.
    JD
