" /> LRM ICON Connections? - Genesys CTI User Forum
Author Topic: LRM ICON Connections?  (Read 5529 times)
Offline PFCCWA
« on: February 04, 2016, 11:36:03 PM »
I am deploying LRM 8.1 and cannot find a definitive list that is required for the ICON application connections.
So far I have found connection is required for the t-server and ocs.
what about GAD, Workspace, URS, ivr t-servers?
We are not using eservices so do not need interaction server.
thanks.
Offline Timur Karimov
Re: LRM ICON Connections?
« Reply #1 on: February 05, 2016, 09:57:38 AM »
Hi there
all license usage events is based on register/free model within the T-Server logic's. So if you have connection to you T-Server  than you have all events about agent login/logout, dn register/unregistered, etc.
For OCS it's the same - usage of agent in predictive/progressive(occ_full) or preview campaign it's a result of event/response in OCS. So again: you have connection to OCS - you have all info about license usage correspond to OCS: agent, cpd, etc.
And that exactly what you need for LRM.
Only one separate connection in LRM you need: if you use the GVP you should connect your LRM to GVP Reporting Server. And GVP Reporting Server should't be used in no-db mode.
WBR Timur
Offline PFCCWA
« Reply #2 on: February 05, 2016, 10:52:23 AM »
thank you.
also for the LRM database, there is no mention on what user permissions are required, say for an oracle db.
I was going to use the same permissions as described in the icon deployment guide-  is this the right way?
regards.
« Reply #3 on: February 08, 2016, 09:21:57 PM »
[quote author=PFCCWA link=topic=9349.msg42193#msg42193 date=1454669543]
In my test with Oracle DB I just create new user with standard schema rights as for icon. But don't forget what Oracle and MS SQL is essentially different in that question.
WBR Tim
« Reply #4 on: February 16, 2016, 05:52:17 AM »
Hi.
perhaps this news will be worthwhile for you: looks like Genesys start to "shutdown" they own license management solution and now suggest to use the Blackchair Spotlight.
WBR Tim.
« Reply #5 on: February 16, 2016, 11:06:10 AM »
[quote author=Timur Karimov link=topic=9349.msg42286#msg42286 date=1455601937]
Hi.
WBR Tim.
;D ;D Really!!?? Genesys never stops amazing me with their dummy product live cycle on some "revolutionary" ideas.
Offline Fra
« Reply #6 on: February 16, 2016, 12:08:27 PM »
Eh?? That would be surprising..
« Reply #7 on: February 16, 2016, 12:16:00 PM »
Has anyone more information about mentioned product change? I have read some newsletter about that, but without any details.
« Reply #8 on: February 16, 2016, 01:46:38 PM »
Check this
http://www.genesys.com/resources/datasheets-and-brochures/Spotlight_-_blackchair_datasheet_Oct_2014.pdf
and this
https://appfoundry.genesys.com/home#!category/4870
No official mention but seems a logical move
Offline Fra
« Reply #9 on: February 16, 2016, 02:48:13 PM »
I used Spotlight.I don't mean to be harsh, but unless you are interested in tracking and rolling back config changes, well, it does not offer any critical functionality that you can't either implement or find in other tools.
As far as I recall, that version I tried did not have anything related to tracking licenses: in fact, it connected just to config server and message server.
Fra
