" /> Disposition code not mandatory on manual outbound call - Genesys CTI User Forum
Author Topic: Disposition code not mandatory on manual outbound call  (Read 2309 times)
Offline Kenka
« on: March 02, 2016, 04:26:33 PM »
Hi all,
I want to have the disposition code to be mandatory for inbound calls, but not for manually dialed outbound calls.
When I set the option interaction.disposition.is-mandatory to true on WDE 8.5.1 that also makes them mandatory for the manual calls.
Is there any way to achive this, haven't found an answer here or in the Genesys documentation?
Offline PeteHoyle
Re: Disposition code not mandatory on manual outbound call
« Reply #1 on: March 02, 2016, 04:43:49 PM »
One way could be to set the option interaction.disposition.is-mandatory to false and then override that value to true in your routing strategies for inbound calls.
Quite a lot of admin but it should achieve your aim of mandatory disposition codes for inbound calls only.
Modified: 8.5.000.xx
• Default Value: false
• Valid Values: true, false
• Changes take effect: Immediately.
• Description: Specify whether it is mandatory for the agent to set a disposition code
before Marking Done an interaction. [color=red]This option can be overridden by a routing
strategy, as described in Overriding Options by Using a Routing Strategy.[/color]
Offline Kenka
« Reply #2 on: March 07, 2016, 08:41:35 AM »
Thank you Pete, I got it working that way.  :D
