" /> Dialling Duration - Genesys CTI User Forum
Author Topic: Dialling Duration  (Read 2060 times)
Offline cjenkins82
Dialling Duration
« on: March 09, 2016, 11:38:15 AM »
In Genesys administrator does anyone know where I would change the length of time we call the number before the treatment kicks in? It's currently set to 30 secs but I want to change it.
Re: Dialling Duration
« Reply #1 on: March 09, 2016, 01:41:35 PM »
Try to specific which type of switch are you using. In case, the Genesys SIP, I guess you meant the option "sip-invite-treatment-timeout". But, try to be more specific in your description to be able to help you.
Offline caractacus
« Reply #2 on: March 10, 2016, 08:50:29 PM »
Can you be a bit more specific.
How are you calling? Is this  an outbound call initiated by OCS and you are after the option to determine how long before a no answer call result is determined sono answer treatement kicks in?  ( the option is call_wait_connected_timeout which you can set at OCS application level or campaign group level)
Or is this for a manually dialed call, in which case what treatment are you referring to?
