" /> How to get max and min advisor logged in from stat server - Genesys CTI User Forum
Author Topic: How to get max and min advisor logged in from stat server  (Read 2496 times)
Offline Dimitry
« on: July 14, 2016, 12:24:03 PM »
Hi All,
Could you please let me know how I can get the max and min advisors logged in for voice channel a particular interval (15 min) from stat server?
What custom stat should I create to display this in CCPulse?
Senthil
« Last Edit: July 14, 2016, 12:37:53 PM by Dimitry »
Offline Tambo
Re: How to get max and min advisor logged in from stat server
« Reply #1 on: July 14, 2016, 01:03:03 PM »
do you have historical reporting set up for ccpulse ??  some do some don't
Offline Dimitry
« Reply #2 on: July 14, 2016, 01:13:38 PM »
Hi Tambo,
There is no historical reporting in CCpulse.
I would need the custom stats to be defined in the stat server.  Then I could use the SDK to get the information for a 15 minute interval period.
what customer stat should I define to get this ?
Senthil
Offline Tambo
« Reply #3 on: July 14, 2016, 02:44:52 PM »
ok then so you would need to pull this info from GIM (Info Mart the historical reporting DB)  not stats server as it's not historical
