" /> Tenant View stats - Genesys CTI User Forum
Author Topic: Tenant View stats  (Read 4153 times)
Offline anandapriyan
Tenant View stats
« on: September 13, 2016, 10:48:20 AM »
Team,
In CCPulse, In the [b]Tenant [/b]view for [b]Email [/b]and [b]Chat[/b] media, the [b]stat values[/b] are[b] not get updated[/b].It shows only 0 for Email.
In[b] Chat[/b] some of the stat values are displaying in the decimal values. Kindly looking forward for your Possible suggestions.
Re: Tenant View stats
« Reply #1 on: September 13, 2016, 11:16:40 AM »
StatServer logs?
Offline Tambo
« Reply #2 on: September 13, 2016, 01:27:31 PM »
check stats server section in options tab in the stats server for time format
have you made the media types up in the CCPulse application options tab for CustomStatistic?
« Last Edit: September 13, 2016, 01:31:57 PM by Tambo »
« Reply #3 on: September 19, 2016, 11:13:39 AM »
I have made the [b]media types up[/b] in the [b]CCPulse application custom statistic tab[/b].
Here this is the time format we are using [b]%m/%d/%Y %H:%M:%S[/b] under time format in the stat server section.
What are the changes to be done.? , To get the values loaded in the CCPulse.
Only some stats are getting loaded while testing an multimedia.
« Reply #4 on: September 28, 2016, 07:56:30 AM »
Team,
Any reply for that issues mentioned.?
Offline Tambo
« Reply #5 on: September 28, 2016, 08:41:55 AM »
did you make your custom stats correctly ?
« Reply #6 on: September 29, 2016, 07:01:22 AM »
In General Email Handling, I have configured the following stat for the Total Entered stats in the tenant view.
General_email_handling : Total Entered:
JavaSubCategory - eServiceContactStat.jar:total entered
Category - JavaCategory
Objects - Tenant
AggregationType - Total
But its not getting updated. It always shows values as zero. Kindly looking for the possible solutions.?
« Reply #7 on: September 29, 2016, 07:05:48 AM »
The Java environment is initialized properly for StatServer instance? What says log?
« Reply #8 on: September 29, 2016, 02:22:24 PM »
Yes i have the following options in the stat server:
I have Java Config and Java Extensions.
And the following JAR file to TRUE:
[b]eServiceContactStat.jar
eServiceInteractionStat.jar
eServiceSystemStat.jar[/b]
And in the Stat server Option, I have set the[b] Enable Java [/b]- [b]TRUE[/b].
« Reply #9 on: September 29, 2016, 04:44:07 PM »
And do you see within the logs that the JVM env is initialized properly (with all .jar files)?
