" /> Import Wizard features in 8.5 / GAX ? - Genesys CTI User Forum
Author Topic: Import Wizard features in 8.5 / GAX ?  (Read 1892 times)
Offline n3vek7
    • ITKB
« on: October 31, 2016, 01:41:31 PM »
Hey Guys,
Do you know if features like Import XML, Export objets, etc. (from Conf Import Wizard) are available in ConfServ 8.5 with GAX? I haven't found a way to import raw data xml in confServ so far. (to be honest, I have not search a lot, I just want to know if I should to search MORE or not !!)
Here's the list of the main feature ;
[b]- Import switch configuration data[/b]
-- Switches data (Avaya, Aspect, etc.)
-- Raw XML data
[b]- Import agent data[/b]
-- LDAP
-- AD
-- Raw XML
[b]- Export config data[/b]
Thanks.
« Last Edit: November 02, 2016, 11:22:28 AM by n3vek7 »
Offline n3vek7
    • ITKB
Re: Import Wizard features in 8.5 / GAX ?
« Reply #1 on: November 15, 2016, 03:14:21 AM »
Nobody ?  :'( :-[
Btw, GAX is awful... (only good thing I saw so far is adding capacity rules and the plugins...)
