" /> Original OtherDN overwritten by IPCS ID after jump to strategy. - Genesys CTI User Forum
Author Topic: Original OtherDN overwritten by IPCS ID after jump to strategy.  (Read 2425 times)
Offline Gef Buneri
  • Madness is just a point of view.
« on: November 10, 2016, 01:48:59 PM »
Hi all, as in object, when using a strategy with jump to strategy block, the destination CTI linked to an extension DN, shows an IPCM port (6xxxx) as CallerID, instead of original CallingID number.
Any tip?
IRD 7.5, URS 7.5, TServer 7.5, Avaya CME 3.1, Siebel Gplus CTI.
Best regards,
Gef.
***EDIT***
Overwritten or lost value seems to be the "OtherDN" value; in the first call, the OtherDN is the ANI[], in the jumped interaction becomes an IPCM port (6xxxx).
« Last Edit: November 10, 2016, 02:06:39 PM by Gef Buneri »
Offline terry
Re: Original OtherDN overwritten by IPCS ID after jump to strategy.
« Reply #1 on: November 13, 2016, 03:38:02 AM »
Check what strategy(ies) do.
Strategy jumping by itself is logical operation and not able to affect any CTI parameter.
Other DN can be changed result of somebody (something) move interaction to another DN.
Offline Gef Buneri
« Reply #2 on: November 15, 2016, 09:00:51 AM »
Thanks Terry, I'll look in that direction.
Another doubt; there's a way to retrieve in URS the Calling Name value from h.323 CM3?
Regards.
« Reply #3 on: November 15, 2016, 02:06:57 PM »
Would be a TServer task, if TServer attach it somehow then you can grab it
Offline Gef Buneri
« Reply #4 on: November 15, 2016, 02:39:21 PM »
Think I can't attach something from pbx to tserver/urs; was thinking about some tserver feature/option.
« Reply #5 on: November 15, 2016, 03:30:43 PM »
Check your TServer guide. If there is anything about h323
Offline Gef Buneri
« Reply #6 on: November 15, 2016, 03:38:25 PM »
Yep, was looking there. I'll keep you informed.
