" /> Siemens OpenScape AttributeDN/ThisDN contains IP?!? - Genesys CTI User Forum
Author Topic: Siemens OpenScape AttributeDN/ThisDN contains IP?!?  (Read 1940 times)
Offline Jason16v
« on: December 14, 2016, 06:05:11 PM »
I'm encountering a scenario where I have SIP integrated with OpenScape. The scenario I'm having issues with are where a call is initiated from the Siemens hardphone.
What I see in the logs is that the AttributeDN/ThisDN is being set to the extension + ipaddress so it shows up as 12345.10.1.1.1. Since my client is registered on 12345, these messages are never received by the client from SIP server.
Question is there a way to change this behavior? This only occurs for these call scenarios.
Thanks in advance!
Re: Siemens OpenScape AttributeDN/ThisDN contains IP?!?
« Reply #1 on: December 14, 2016, 08:26:03 PM »
so...who is setting that IP Address? Never saw SIP Server do that. Might be the other leg, you need to isolate the call scenario
« Reply #2 on: December 15, 2016, 07:13:09 AM »
This should cause in multi-site env with SIP servers, where the same numberic plan is used under each site. How does you environment look?
