" /> Routing point spec - Genesys CTI User Forum
Author Topic: Routing point spec  (Read 1799 times)
Offline hieutx
Routing point spec
« on: June 06, 2017, 07:56:03 AM »
Hi all,
I want to create scenario routing to the agent served on the previous call.
please help me.
Re: Routing point spec
« Reply #1 on: June 06, 2017, 08:30:19 AM »
Use LastAgent function
Offline hieutx
« Reply #2 on: June 06, 2017, 09:04:58 AM »
Hi you,
thanks for support.
I find that i don't see this function. please send to me info detail.
Customer A send request and be served by agent X. When Customer A send request again, Agent X will be selected.
do it resolve this problem?
« Reply #3 on: June 06, 2017, 10:18:46 AM »
Yes, it will solve this situation. In case, you have installed UCS, than just use UCS for this purpose (LastAgent field is already there). In other cases, you have to achieve that through another way - for example storing the information to the database.
