" /> ActiveX or Softphone - Genesys CTI User Forum
Author Topic: ActiveX or Softphone  (Read 3562 times)
MSC
I may not have my facts right but for integration to a client application there is the Genesys Desktop Toolkit complete with ActiveX objects.
Is there also a softphone client that provides hooks such as DDE and OLE or is this the same thing??
  • Active X sample uses TLibrary to directly connect to TServer. You will not need anything else. I would avoid DDE functionality, if it is at all possible. Wha are you trying to do, if I might ask?
