" /> Config database - simple question - Genesys CTI User Forum
Author Topic: Config database - simple question  (Read 3535 times)
Offline blacklord
« on: May 01, 2008, 05:31:49 AM »
Guys,
Is there a simple way to export everything from the Config database via CME ?
Lance
tony
Re: Config database - simple question
« Reply #1 on: May 01, 2008, 07:58:59 AM »
Using CME directly = no.
Using the [i]Config Export Utility[/i] = yes.
Tony
Offline thicke
« Reply #2 on: May 01, 2008, 12:36:59 PM »
You can also export the entire config database into an SQL file using the Configuration Conversion Wizard. This file can only be imported again by CCW though.
Offline S
« Reply #3 on: May 01, 2008, 07:17:14 PM »
if you are setup with SOAP port for config server and have CIW license,
then your CME should already have CIW interface option in the File menu. Use it to export the config DB. It exports as XML though..
Offline blacklord
« Reply #4 on: May 02, 2008, 02:49:32 AM »
Thanks guys
